I am trying to take a psql grafana backup from Grafana 8.5.10 and restore it to the 9.3.6 version. I am facing this issue.
{“error”:“pq: column \“last_used_at\” does not exist”,“level”:“error”,“logger”:“context”,“msg”:“Failed to get settings”,“orgId”:0,“t”:“2023-09-05T10:51:33.675277103Z”,“uname”:“”,“userId”:0}
This column last_used_at is not present in the Grafana 8.5.10 db schema.
Whether the complete Grafana DB backup allowed from the older version to the latest Grafana version?
Thank you for your response @yosiasz
I am looking for a scenario where I can take a backup from Grafana v8 and restore it on another cluster where Grafana v9 is installed.
In that case, Do I need to take the backup of the particular tables where the custom data is stored for example custom dashboard?
If only in the order of tenth, I suggest just export the dashboard to json, then import to the new Grafana. Don’t forget to create the datasource first in the v9 same as the old one.
