10.0.3
kube-prometheus-stack-55.4.1 v0.70.0
- What are you trying to achieve?
only 10 days of data is present and stored in chunks of data.
- How are you trying to achieve it?
Why the older data is being deleted without any version upgrade
- What happened?
All custom created alerts and dashboards are being deleted and also the dashboard is showing only past 10 days of data.
It is also deleting the administration users leaving the admin
Please help with this, It happed munltiple times.
Please Help, It is Priority for me…
Data is present in the existing dashboard only from 6th of Jan, before that everything is deleted. All the custom dashboards and alerts which I configured are erased.
When facing data deletion issues with kube-prometheus-stack Helm chart, check your configurations and persistent storage settings Resimac Manufacturer. Ensure proper volume mounts for data persistence. Additionally, exploring community forums or reaching out to Helm chart support might shed light on specific solutions. Best of luck resolving this data retention challenge.
