9.2 -
upgrading kube-prometheus-stack from 10.0.2 to latest version -
Upgrading step by step from kube-prometheus-stack 10.0.2 to 41.9.1 through helm chart using the official documentation provided by helm => kube-prometheus-stack 41.9.1 · prometheus/prometheus-community -
What happened?
During the upgrade process from the version 21.x to 22.x, there is an instruction to delete the kube-state-metrics
[kubectl delete deployments.apps -l app.kubernetes.io/instance=prometheus-operator,app.kubernetes.io/name=kube-state-metrics --cascade=orphan
I lost all my metrics data,even though PVC is mapped to prometheus
post upgrade to 22.x, I am not able to see the history data.
I am expecting all my historic data should retain post upgrade to latest version -
all the older data is lost -
Grafana dashboards view is also changed post upgrade -
I followed the below URL for the upgrade process
Now i am planning to perform the similar upgrade in my Production environment, but the historical data is very critical and cannot lose it. How can i upgrade without losing my historic data? otherwise did i missed anywhere to update any parameters in the values file?
Please advise, thank you in advance!!
Regards
Vamsi
