Dashboard variables or time windows set while viewing a single panel are lost when returning to dashboard
Grafana v9.5.21
Set a variable value or time window while viewing a panel, then return to main dashboard preserving that value. This was the behavior (I believe) on previous versions of grafana, but I cannot determine how to replicate it on grafana v9.
  1. View a single panel in a grafana dashboard, having clicked “View” to make that panel occupy the entire screen.
  2. Based on observations from that panel, set dashboard-level variable
  3. Return to the full dashboard by clicking its name at the top left.
  • What happened?
Upon returning to the main dashboard, the time window or variable value resets to the dashboard default.
I expected the time window or variable value I had set to be preserved upon returning to the main dashboard.
I easily reproduce this on any dashboard.
No error; it seems to be a behavioral change across versions. I (and several teammates in a large organization) am trying to determine how to obtain the previous behavior, which we find extremely valuable while debugging outages.
No—I searched but did not successfully find any recipe.
