Dashboard Row Variable Reference
    Grafana v10.4.18
    I have panels that show response times for each endpoint in my k6 test. The way my test is setup is each scenario has a serviceName tag. That is essentially the name of the overall app endpoints im testing. Then each http request made inside that scenario has a serviceEndpoint tag which references the name of the endpoint that I am testing inside the service name. I am trying to setup my grafana dashboard so that I can select any number of service names and then it will create a new row for each service name selected and then inside each row hav a new panel created for each serice endpoint inside that rows serviceName.
    To try and achieve this I have my rows set to repeat for every serviceName and then I have panels set to repeat for each serviceEndpoint. This works when there is only one ServiceName selected however when more than one name gets selected the panels break because since in my query I am using serviceEndpoint, that variable is no longer a single variable so the panels switch to “all” instead of the serviceendpoint they were originally for. Example image shows when one serviceName is selected vs when multiple serviceNames are selected
  • What happened?
    The panels did not reference the row name and instead are referencing the overall service name causing them to not duplicate correctly
    I expected the panels to reference the specific rows service name and create the panels inside the row based on that
    Panel Query
    from(bucket: “k6_metrics”)
    |> filter(fn: (r) => r[“envName”] =~ /${envName:regex}$/)
    |> filter(fn: (r) => r[“serviceName”] =~ /${serviceName:regex}$/)
    |> filter(fn: (r) => r[“serviceEndpoint”] == “${serviceEndpoint}”)
    |> filter(fn: (r) => r[“_measurement”] == “http_req_duration”)
    |> filter(fn: (r) => r.status =~ /204|200/)
    |> filter(fn: (r) => r[“_field”] == “value”)
    No :frowning:
    Nothing I could find was similiar to this issue. I essentially need a variable name I can use that references the row name
Could this be the issue?
should it also be something like this?
|> filter(fn: (r) => r[“serviceEndpoint”] =~ /${serviceEndpoint:regex}$/)
Sadly that didn’t work either. We weren’t able to find a way to reference the row name since it is variable and repeated based on a variable. It would be nice if there was a variable we could reference that gives us the current panels row name since there isnt a way to get it if its dynamically repeated off a variable
