Dashboard pending review since September 4 – MySQL MGR / Group Replication Monitoring & Troubleshooting
  • What happened?
Hi Grafana Team,
I submitted a community dashboard on September 4, 2026, and it is still showing Pending after about 11 days.
Dashboard name:
This dashboard is specifically designed for monitoring and troubleshooting MySQL 8.0 Group Replication (MGR) environments.
It was built and tested against a real multi-cluster production environment consisting of 7 MySQL MGR clusters / 21 MySQL nodes.
The dashboard focuses on Group Replication metrics including:
  • Group and member health/status
  • Primary member monitoring
  • Multi-cluster member topology
  • Remote/Local transaction queues
  • Certification Queue
  • Certification Conflict Rate
  • Local Rollback Rate
  • Group Replication transaction throughput
  • Host-based legends for easier troubleshooting
  • Multi-cluster monitoring from a single dashboard
The dashboard uses Prometheus with mysqld_exporter, including Group Replication metrics from performance_schema.
The dashboard has already been successfully imported and tested before submission.
Could you please confirm whether the dashboard is still waiting in the review queue, or whether there are any changes required from my side?
I would also be happy to make any adjustments needed for publication.
Thank you for reviewing the submission.
I’m also working on a v2 revision, which will add TPS/OPS monitoring and additional troubleshooting information after the initial version is published.
Hello @diagdba welcome to grafana community
Have you mentioned the Grafana version and operating system you are using? If not, please add those details to your post and follow up with the Grafana team via email/support.
Thanks, and keep up the great work!
grafana version :Grafana v12.0.1 (80658a73c5)
#operating system :Ubuntu 22.04.3 LTS
Dashboard ID:25750
LGTM: https://grafana.com/api/dashboards?orgSlug=microbunting2091
Be patient - it is slow process:
Yes, this process can take a few days, but congratulations! Your dashboard is now active. :tada:
