Dashboard panels move on refresh (only specific panels)
I’m experiencing an odd behavior in a Grafana dashboard.
On every page refresh, only two large Time Series panels slightly change position/size, while all other panels remain fixed.
The dashboard is saved and I’m not using auto layout.
Notes:
  • The issue only happens with large Time Series panels
  • They contain multiple series (upload + download)
  • Gauges and smaller panels do not move
  • Tooltip is already set to Single
  • The issue happens only when refreshing the page
My goal is not to change metrics, units, or visuals, but simply to keep the panels fixed in the grid between refreshes and future access.
Has anyone seen this behavior or knows if there is a way to lock panel positions?
Thanks in advance.
