Latest as of posting
I am writing the json model for my dashboard mostly manually (for importing / provisioning). This works great. Currently I am repeating the
"datasource": {…}block for each panel. This is fine, if panels have different datasources. But if all of my many panels have the same, it would be nice, if I would only need to write it once (DRY). -
A way to declare it globally (maybe as a “default”. Panels not setting it would inherit that)
What should I paste here?
Did not find anything telling me how to declare that global default.
datasources are per panel so that would break the data model
Can you please elaborate on what would break if a dashboard json for importing has a “default” datasource. So that panel without one would use that?
Use dashboard variable. See for example AWS EC2 | Grafana Labs
