we use dashboard provider config file to load all dashboards in /var/lib/grafana/dashboards, but dashboard json file has __input object to set datasource, how to set datasource default value ?
You’re using exported databases via dashboard -> share -> save/view json which you shouldn’t use. You need to use the dashboard json from dashboard -> settings -> view json
Marcus
