6.7.4 -
I want my custom panel to change the time range whenever I zoom (in/out) just as grafana panels do. -
I get the zoom values (new date range), I try to refresh the page with the new values in the query -
What happened?
It displays a prompt that asks me if I want to refresh the page. It is not natural -
I expected it to be as fluent as the grafana panels -
welcome to the
forum, @toubibharmony
Grafana v 6.7.4 is ancient by our standards. We don’t even really support Grafana 7 anymore. Highly recommend you upgrade to grafana 9.
For anyone landing here 8 years later looking for an answer to a similar question. Check out Plugin migration guide | Grafana documentation for some good examples on using the locationService which you can use to update the from and to in the URL. The time in the URL is used to update panels.
