Hi. I’m using Infinity plugin- JSON file as a data source. My data is a non timeseries value. Is it possible to create a custom table? Like this image below.
Hello
Please post your data in csv inline format. Hard to work with data as image ![]()
Please repost with proper quotation mark. if you copy it here https://jsonlint.com/ you will notice it is not valid json.
Also if you could expound more on what result of A1 & B1 mean using the sample data you posted.
“ProductId”: “1”,
“ProductName”: “Product1”,
“ProductType”: “Beverages”,
“OnStockQty”: 50,
“SoldQty”: 10
“ProductId”: “2”,
“ProductName”: “Product2”,
“OnStockQty”: 25,
“SoldQty”: 20
“ProductId”: “3”,
“ProductName”: “Product3”,
“OnStockQty”: 10,
“SoldQty”: 50
“ProductId”: “4”,
“ProductName”: “Product4”,
“ProductType”: “Canned”,
“OnStockQty”: 30,
“SoldQty”: 40
“ProductId”: “5”,
“ProductName”: “Product5”,
“OnStockQty”: 30,
“SoldQty”: 50
“ProductId”: “6”,
“ProductName”: “Product6”,
“ProductType”: “Dairy”,
“OnStockQty”: 60,
“SoldQty”: 70
“ProductId”: “7”,
“ProductName”: “Product7”,
“ProductType”: “Frozen”,
“OnStockQty”: 70,
“SoldQty”: 80
“ProductId”: “8”,
“ProductName”: “Product8”,
“ProductType”: “Cleaners”,
“OnStockQty”: 80,
“SoldQty”: 90
“ProductId”: “9”,
“ProductName”: “Product9”,
“OnStockQty”: 90,
“SoldQty”: 40
“ProductId”: “10”,
“ProductName”: “Product10”,
“ProductType”: “Personal Care”,
“OnStockQty”: 15,
“SoldQty”: 100
“ProductId”: “11”,
“ProductName”: “Product11”,
“OnStockQty”: 44,
“SoldQty”: 50
Could expound more on what result of A1 & B1 mean using the sample data you posted.
start out with this just to get you going. Done for the day on this side of the world.
See this
--using UQL of infinity.
parse-json
| project "80~100"=sum("OnStockQty","SoldQty")
Then do have idea on how can I create a row header (label) on the table?
looking at the sample data and the results you show in orange does not seem accurate. in the picture you added for inStock 0~19 and SoldQty 80 ~100 the count is 1?
If you check the Product 10, the OnStockQty is 15 and SoldQty is 100 that’s why the result is 1 in the tally (highlighted with orange). If you find my tally incorrect, please disregard. I just manually created that on excel to visualize what I want to show in the Grafana. But the idea is to tally the count of the product based on the range set on OnStockQty and SoldQty.
