CSV file as a datasource
Does grafana allow using csv file as a datasource?
I have a plain text file where there are certain data in space seperated format as well. Can this be displayed in a table format on graphana?
Thanks
Shiva
Not directly. It would probably be fairly easy to build your own data source with the simple json data source. Or you could import into MySQL and use the MySQL data source.
