Hi there.
I’ve just discovered Grafana and am very excited to start using it.
I have looked through the existing posts to ensure I am not duplicating a question so as to not clog up the system with dumb questions. I am looking for some basic guidance on how I start.
In short, I have a client that uses a SAAS for their client data can only be accessed by logging in and manually extracting the data. I am working with the software house to get API access to it, but that’s a little way off yet. We can get that data out, but for Grafana to use it I would like to insert that (CSV) data into source that it recognises. I see there are 9 “native” ones and 50+ add-on options, but - oh - so many choices.
From my initial research I see that Grafana does not support CSV files natively, so I would need to insert that data into something else.
Now, I am a Filemaker developer so can semi-automate the input of this data into Filemaker Server but would need the ability for Grafana to then extract and chart that data afterwards.
Does anybody know a way that I can use Filemaker Server as a data source?
If Filemaker Server is not an option, can anybody suggest a supported data source backend that might be best suitable for importing the data into on a daily basis? We realise it will be manual, but will try to reduce the overall handling of it.
I was thinking of perhaps setting up a MySQL (or similar) database on one of my Linux boxes as an alternative.
Any suggestions or feedback would be appreciated.
Many thanks in advance.
Hi dividebyzero,
Personally i prefer to SQL datasource because of its ability to agregate data.
for this purpuse you can use this app:
If you want to read csv files ‘directly’ you have several options (I know the first two coders):
Regards.
Hi Daniel,
Thank you for responding.
To get started, I will look at those first two options. I see I have to install them but that shouldn’t be too much problem. As I get it moving along, I will follow your advice and move to SQL - I’ll just need to be more comfortable with getting the data into that.
Many thanks for your help. This will keep me going.
Cheers,
Greg
Good morning.
Opening up an old job with a related question…
If we assume that I have text file on the Grafana server - whether it be CSV, JSON or anything, what plugin can I use to access this flat file as a data source please? I cannot see how I can can access files locally on this device - as opposed to external.
(I would probably FTP the file onto the Grafana server.)
Any help is appreciated.
Cheers,
Greg
Hi Daniel,
Thank you for this information.
I am struggling to get the file to compile - reports all sorts of errors - but I will persevere.
Greg
I have never tried to compile it, sorry
No problem Daniel. I was just going by the instructions on the Github page to get it operational - which I assume is the only way for Grafana to be able to use it.
Don’t know if you are still interested in this, but I have an open source node project CSVServer to do exactly this - read a CSV file and serve it up to the SimpleJSON datsource (or the newer JSON datasource) for Grafana.
Takes something like this:
date,val1,val2,val3
2020-04-03 10:00:00.000,90,73,37
2020-04-03 10:30:00.000,80,84,46
2020-04-03 11:00:00.000,70,80,55
2020-04-03 11:30:00.000,70,80,55
2020-04-03 12:00:00.000,60,65,44
2020-04-03 12:30:00.000,85,46,54
2020-04-03 13:00:00.000,74,67,63
2020-04-03 13:30:00.000,68,58,85
2020-04-03 14:00:00.000,71,79,65
2020-04-03 14:30:00.000,71,79,65
and turns it into this…
