We are trying to achieve data visualization from dataloggers pushing .csv files. (ftp push) - every 1 minute we have some data coming with timestamp (1 header and 1 record).
so our data source is an SMB or FTP location with all the incoming .csv files.
Those files need to be consumed, meaning extract the record and keep it as historical data, then delete the file consumed. (This can be done externally if there is no such tool in Grafana).
i have check the infinity plugin data source from csv, but seems that is static data source one time import from csv, not continuously like we have.
Can i have some suggestions / directions for achieving something like that ?
I have checked for online directions on this subject but didn’t find something appropriate.
No , at this time we don’t do that. we are looking for a possible solution. I’m just stating that those files need to be consumed because they will add up to several thousands over the course of some days.
I’m examining whether i have to do this externally with another server / app and load to a database, or there is something ready in Grafana, or i should contribute for a plugin doing that in Grafana.
ah gotcha, so with grafana you could use some plugins that could aggregate those files and visualize them but wont be optimal approach. you have tons of options depends on your in house expertise.
