I am trying to visualise data using a csv file as a data source using the CSV plugin and then creating a bar graph.
It works perfectly when there is only one row of data after the header row in the csv
But I want to visualise for example the third row of data.
Can someone help me with how to transform the data.
Using Grafana version 9.3.2 and CSV plugin version 0.6.5
