v9.3.2 on Kubernetes -
I am trying to create a notification policy via the API. -
Alerting Provisioning HTTP API | Grafana documentation
There is no POST method for creating a notification policy
What happened?
I am getting a 404 not found error. -
I expected the Notification Policy to be created
But I also noticed that the http provisioning docs leave out the POST method for creating a notification policy. DELETE, GET, and PUT exist but not POST -
endpoint = "<grafana-url>/api/v1/provisioning/policies"
payload = {
"receiver": "test_alert_name",
"object_matchers": [ ],
"routes": [
"object_matchers": [["alertname", "=", "scanappAlert"]],
Sending a post request and getting a 404 Not found error
No -
