Grafana 9.0.0, Kubernetes on Debian -
I want to automate the creation of alerting rules, notification policies and contact points -
Using the documented ‘Alerting Provisioning API’ -
What happened?
After I created the objects over the API, I can’t manually edit the created objects in the UI -
I want to create the objects via the API, but also want to use the UI to edit the created objects -
Error-Message in the ui:
Python-Code to create the notification policy:
obj = {
"receiver": "test@test.de",
"object_matchers": [],
"repeat_interval": "8h",
"routes": [
"receiver": fullSN,
"object_matchers": [["sn", "=", sn]],
resp = session.put(grafanaParsedURL + "/api/v1/provisioning/policies", json=obj)
I created a issue at github: Create Alerts, Notification Policies via REST-API · Issue #51455 · grafana/grafana (github.com)
