9.4.7
Create a policie and a rule group using API
Create a rule group inside a the /api/v1/provisioning/alert-rules with a customized interval ( defaul is 1 m) -
Follow the documentation, using the rest APIs.
- What happened?
Did not find on the docs the post route for Notification policies.
For the rule group after the creation of a rule I need to use the put inside the new rule group to change the interval ( is that the correct approach? seems wrong to me)
Expect to be able to create a policie using API. I’m creating a web site were I will create the alerts. I need to create everything using APIs. The rules works well, also the contact points but without a policie I cannot connect both.
Create a rule and define the interval for the rule group
- Did you follow any online instructions? If so, what is the URL?
Alerting Provisioning HTTP API | Grafana documentation
