Create a State Timeline chart from MariaDB data with Starting and Ending Times
    Grafana 10.4.1 running locally on a Linux computer
    I am trying to query a MariaDB table of weather events for four counties and “graph” that into a State Timeline chart with each county on a line, and the events color-coded by what type of weather event they were. The source table contains two time fields: the starting time for the event and the ending time for the event. I am looking for an output table along the lines of this:
    My source data looks like this:
    I am starting with the following SQL query:
    SELECT Event_UUID, Phenomenon, Significance, County, EffectiveTime, EndTime FROM SCADA_Automation.`Weather_Events.0000`
    However, I cannot figure out how to get all of this into a single data series with the attributes that I need and the correct “On” and “Off” times.
  • What happened?
    I got this, which is decided not what I was after:
    I wasn’t sure what to expect, but I wanted this:
    I really am not getting far enough with this to be “having problems” with any specific configurations. I just can’t get it to work at all.
    I did not get any errors…I just didn’t get anything useful, either.
    No. I couldn’t really find any instructions for what I am trying to do.
Use State timeline and try query in the format:
-- Start events
SELECT
  timestamp AS time,
  column_metric AS metric,
  column_value AS value
FROM table
WHERE
  timestamp <= ....
UNION ALL
-- End events (set value to 0)
SELECT
  timestamp AS time,
  0 AS value
FROM table
WHERE
  timestamp <= ....
ORDER BY time ASC, metric ASC
LIMIT 100
Set value mapping: 0 → transparent color; color mapping, …
