Hello all,
I’m having a problem with the time series panel and my mysql data, here’s the recap:
v8.1.3 on Docker -
I’m trying to get something like this:
To be honest, I’m not sure where to begin. I’ve tried vartious settings, but I can’t figure it out. -
What happened?
Basically, I used a state timeline panel, using mysql as the source, but I’m stuck here. I can put a start time, but no end time. -
I expected to be able to put some kind of title on each row, which would be the id of the job. Then, I was expecting to have some kind of way to put a start time and end time. Based on the status of the job, I was expecting to be able to color the timeline matching the status (success or fail). The periods of time where nothing happens in-between executions would be greyed out. -
I haven’t done much, so it wouldn’t be any use. Here’s a screenshot of my DB, and the fields I was planning to use:
No -
I tried to use this, but I can’t really figure out how it could help me in my situation
Thank you for your help !
