9.2.3 -
Using Polystat plugin using reduce transformation at the end for Severity & Count -
What happened?
Not able to superimpose the Count over Alert Severity based Circle.
Circle denotes Top severity of alert and Count is number of alerts for specific technology.
Currently it is allowing to use only 1 metric to be used for defining threshold which is use.
