Correctly recognize special date format in table
Good day
I am using an Ubuntu Server 22.04.2 LTS and the Grafana version is v9.3.6. I use Grafana in combination with InfluxDB2.
In a dashboard I use a table and in it I have a column with a timestamp. Unfortunately I don’t have a usual date or timestamp format. How can I still sort correctly by date and get Grafana to recognize this timestamp in this dashboard?
The date has the following format:
21-02-2023 23:16:14.343265955
DD-MM-YYY HH:MM:SS.---------
Thanks for your help
Welcome
So are you saying it currently is not sorting properly for you?
What happens?
Good day
Unfortunately not. See screenshot.
Can I specify the format manually in Grafana?
Hi @ffarkas,
Welcome to the :grafana: community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community :slight_smile:
You can use the Override function to convert the date to YYY-MM-DD Format
I attached a screencast (open it in a new window as will be easier to zoom in and view more clearly)
timestamp-overwrite 2022-09-26 11-46
I hope this helps.
Hello @usman.ahmad
Thank you very much for your answer. Unfortunately I can’t get it to work with:
time: DD.MM.YYYY HH:MM:SS
The format in the database is: 31-01-2023 11:22:46.335538808 and apparently it is not recognized by Grafana.
However, I need DD.MM.YY HH:MM:SS displayed in the table.
Do you have an idea how I can correct this? Is it possible in Grafana or do I have to adjust my InfluxDB query?
Thank you very much for your help.
In the same override instead of hardcoding it, have also look into this “Date & Time” option.
Its hard to share it as screenshot but it will be under Standard Option → Unit and then select Date & Time and try out each of them if that matches your requirement.
Let us know if this helps.
This has saved me . Thanks a lot for sharing it. :slight_smile:
