Grafana v11.3.1 (b58701869e) on Arch Linux
Since it’s about the WebUI, I’m using Firefox 133.0.3 (on Arch Linux too).
- What are you trying to achieve?
I’m trying to copy the thresholds of a panel to another.
- How are you trying to achieve it?
Via the Panel JSON because I didn’t find another way to do it. Maybe it’s not the best way?
- What happened?
Copying Panel JSON don’t work. I’m only getting a fragment of what I selected.
I’m expecting that pressing Ctrl-C or right-click → Copy will copy the whole selection.
Copying this…
…give me that when I paste it:
"thresholds": {
"mode": "absolute",
… "color": "red",
"value": 87.5
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
There is no error.
- Did you follow any online instructions? If so, what is the URL?
No, since I didn’t found any instruction on how to copy only the thresholds without using the JSON, which seems pretty straightforward, but don’t work.
Thanks.
