Hi
I’ve set up a variable based on a query that will return epoc. How can I convert this to appear as local time DD.MM.YYYY HH:mm:ss
This is a variable under dashboard settings, not a metric. No such thing as transformation there I think
O
@sowdenraymond .I can’t find any transformation when working on variables. I don’t know what I’m doing wrong.
To be sure. I’m working on dashborad variables here, not visualization content
you create you variable, and then you can apply transformations to them or use the variables in transformations
