Variables using dates are converted to unixtime
  • What Grafana version and what operating system are you using? Grafana 8.0.6 Centos 7.9
  • What are you trying to achieve? Have grafana not change my results
  • What happened? Grafana converts variable results from a date to unixtime by itself
  • What did you expect to happen? It not to do that
    In a Table Panel
    SELECT date from sites_config where router_desc = “router”
    Returns
    2020-09-21 09:14:01
    2020-09-25 20:37:24
As a Variable same SQL returns
1628037216000
1626309174000
This worked as expected in Grafana 7.1.5
In Grafana 8 there should be overrides and transformations that you can use to either change the unit appearance or set the data type. Might be helpful to the community if you shared a screenshot of your table and tried to describe what you would like to change :+1:
Had to go back to grafana 7.5, so I don’t have a screenshot. Transformations don’t work on variables in a templated dashboard.
Was there a solution to this?
