[RHEL8 Grafana 12 Sitting behind a firewall installed via RPM - not Docker]
I’m in the middle of configuring Grafana to authenticate with EntraID using Home > Administration > Authentication > Azure ID in the GUI.
I think I’ve set it all up correctly
When I try to login using the EntraID signin button on the Grafana login page, it takes me to Entra to pass my credentials. However, when I’m passed back to Grafana I get the following:
Login failed
Failed to get token from provider
Here’s the relevant output from the log:
logger=context userId=0 orgId=0 uname= t=2025-08-14T18:46:30.798156428+02:00 level=info msg="Request Completed" method=GET path=/login/azuread status=302 remote_addr=****USER-IP-ADDRESS-REMOVED-FROM-POST**** time_ms=0 duration=88.195µs size=477 referer=https://****GRAFANA-URL-REMOVED-FROM-POST****:3000/login handler=/login/:name status_source=server
logger=authn.service t=2025-08-14T18:46:31.292035091+02:00 level=error msg="Failed to authenticate request" client=auth.client.azuread error="[auth.oauth.token.exchange] failed to exchange code to token: Post \"https://login.microsoftonline.com/****TENANT-ID-REMOVED-FROM-POST****/oauth2/v2.0/token\": dial tcp: lookup login.microsoftonline.com: no such host"
logger=context userId=0 orgId=0 uname= t=2025-08-14T18:46:31.3015948+02:00 level=info msg="Request Completed" method=GET path=/login/azuread status=302 remote_addr=****USER-IP-ADDRESS-REMOVED-FROM-POST**** time_ms=18 duration=18.034049ms size=29 referer=https://****GRAFANA-URL-REMOVED-FROM-POST****:3000/ handler=/login/:name status_source=server
The server sits behind our firewalls, so we’ve got a proxy that allows servers to speak to the relevant Microsoft sites for EntraID.
I suspect that I need to set that in Grafana somewhere?
I’ve searched through the documentation but (unless I’m misunderstanding it) the only stuff I can find is to use a reverse-proxy as an actual authentication method.
Where would I set our proxy details so Grafana can reach Microsoft?
Thanks in advance for any help you can offer ![]()
