Configure Motorola Flex and Grafana Cloud
Are there any steps to connecting Motorola Flex(Spillman) with Grafana Cloud?
Hey there! I don’t see any plugins or integrations for Motorola Flex(Spillman) specifically, but in general there are three methods for working with your data in Grafana Cloud:
  1. Using agent-based monitoring: Use agent-based monitoring | Grafana Labs
  2. Shipping metrics and logs with remote_write: Ship Metrics and Logs | Grafana Labs
  3. Visualizing your data in-place with a directly connected datasource: Visualize Existing Data | Grafana Labs
I’m not familiar with the Motorola Flex(Spillman) datasource, so you’ll have more insight here for sure. If you can install Grafana Agent and the application exposes metrics/logs/traces that can be scraped and exported by the agent, then great! If not, is there a way to export data in Flex(Spillman) to a supported datasource like InfluxDB or MySQL? Alternatively, you are welcome to create your own plugin for this!
