Hello!
I added OpenTelemetric to my project.
Creating a dashboard using Tempo and TraceQL.
I create a dashboard variable called httpStatusCode that is a text with the status code number.
I currently have
span.http.status_code=${httpStatusCode}
But this make the variable required. Is it possible to do this only if we set a value to the variable. If the variable is empty let’s not add this condition to the TraceQL query.
Thanks
1.) Don’t use = operator but =~ (regex)
2.) Use wild char as default value for httpStatusCode variable, I gues . *
So by default it will be selecting all status codes, but you will have an option to define custom code.
Hi @jangaraj
Thanks for your answer
I try this
span.http.status_code =~ ${httpStatusCode}
and it didn’t work, also if I hardcode to be
span.http.status_code =~ "*"
I always get not result using `=~`
Maybe because is a number type?
Check the doc for supported regexp, maybe it’s .*
I can’t seem to get this to work for span attributes that aren’t strings. span.kind and span.status both accept enums as values so I can’t think of a way to add a dashboard filter for those values with mulivalue or an all value.
