Traceql select query not working
I am using select(span.http.status_code). When i am making the table type as spans in options,the http status code column is not showing up.This is a problem as i want to do operations based on the status codes of span in dashboard and transforming data is not available without the httpstatus code column in the main table.
How can i include the column in span table?
