Combine timeseries with constant coming from json data
  • What Grafana version and what operating system are you using? Linux open source grafana v10
    Combine two datasources: influxdb and infinitive plugin - json data
    No idea what would be the best approach
    Timeseries data multiplicated by constant from json
Json (infinitive plugin to datasource json from http):
{ flats: [
{flatname : flat01, flatsize : 123},
{flatname : flat02, flatsize : 456}]
Expected result:
influxdb query timeseries multiplicated by 123
This is my intention how to multiply timeseries with a variable (constant per each flat) coming from json. Is this a good approach to do so or would you rather suggest a completely different solution how to accomplish such a task?
Thanks a lot
Ok, to me it seems that Variables-Constant is the easiest way to achieve this. Thus I made a flat01:123 Variable Constant, then an influxdb query with multiplication ${flat01} which is translated to multiplication of 123.
