i’m not a Grafana expert , i want to add variables to my dashboard so here’s my querry :
from(bucket: "test4")
|> filter(fn: (r) => r["_measurement"] == "FourFrittage")
|> filter(fn: (r) => r["_field"] == "variable_value")
|> filter(fn: (r) => r["variable_name"] == "${variable_name}")
|> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)
|> yield(name: "last")
this queery does’nt give the expected result. I’m expecting to have variable where i can choose whcih variable to display in my time series plugin:
grant2
2
Hi @lorry96
Does this example help?
Did you define your variables like this?
Note how my variable syntax below differs from yours:
from(bucket: "EIAtest7")
|> filter(fn: (r) => r["_measurement"] == "ElectricPowerOperations")
|> filter(fn: (r) => r["_field"] == "value")
|> filter(fn: (r) => r["type"] =~ /^${type:regex}$/ )
|> filter(fn: (r) => r["region"] =~ /^${region:regex}$/ )
|> group(columns: ["region", "_measurement"], mode:"by")
|> aggregateWindow(every: v.windowPeriod, fn: sum, createEmpty: false)
|> yield(name: "HourlyData")
