Fluxql grafana variables
I am trying to define a variable named “Host” based on the snmp user agents i have stored in an Influx bucket, but i am missing something …
from(bucket: “bucket1”)
|> filter(fn: (r) => r[“agent_host”]
Hi @mckinley and welcome to the Grafana forum.
Did you define the variable in this screen? In my example, it’s a tag called “region”.
import "influxdata/influxdb/schema"
schema.tagValues(
    bucket: "EIAtest7",
    tag: "region"
In my Flux query, this is how I allow one to select multiple regions:
  |> filter(fn: (r) => r["region"] =~ /^${region:regex}$/ )
Hi Grant,
Thanks for the reply. I’m not sure i follow your logic here. Do i need to modify the database schema to define a variable?
This is what the output from influxdb looks like:
I simply want to be able to iterate over all the host agents in my influxdb
Hi @mckinley ,
grant2 already provide solution for you. You just need to adjust bucket name and tag, so in your case your query for dashboard variable should look like:
schema.tagValues(
    bucket: "bucket1",
    tag: "agent_host"
and all unique agents should be displayed.
You can take a look at influxdb schema tagvalues documentation.
Everything is done in Grafana ( open dashboard → Settings → Variables → New variable ). Nothing will be changed or written in influxdb.
Best regards,
ldrascic
Thank you very much.
It seems to be working, but im not sure why. But maybe that’s an exercise best left to the “reader”
