Grafana Version: v10.1.5
I am trying to create a timeseries panel using InfluxQL. The panel is created with multiple queries and these use different hosts(5). These hosts can be defined as static custom variables. However, I want to define these from Query as they can be fetched from the InfluxDB as the value of host tags.
I am using “SHOW TAGS…” query to get the hosts into a variable. Using this, I can define my query to select the host chosen by the user on the dashboard.
However, my requirement necessitates usage of all the five hosts in the queries and thus I will have to use the index to refer to the individual host from the listed variable.
I have a variable as all_hosts and I can refer to the individual hosts as ${all_hosts.i}, where i can be between 0 and 4 to get the five different hosts. This works fine in the queries. However, I need to refer to these hosts in the panel title as well. But, when I use the same indexing, the value always becomes All and not the actual host the index points to. Additionally, I want to print the host name in the row to group panels related to the individual hosts. There too, this indexing does not work.
In summary, these are my requirements.
- To be able to index a list variable in Panel title.
- To be able to index a list variable in Row title.
Could you please help with this?
Note: Referencing this,, I used the aforementioned indexing inside queries. However, that does not work in Panel and Row title.
Thanks
