10.2.2 - What are you trying to achieve?
I want to have 1 overview for 4 metrics
So i have 4 metrics success, failed, running, queued and they can be 1.
So if success is 1 then the rest is 0
If failed is 1 then the others are 0
I would like to create a stat overview with 1 stat representing one of the 4 metrics.
- How are you trying to achieve it?
I dont know that yet.
I can do a promql giving me all the metrics == 1
(airflow_dag_last_status{host=“lspe000763”,owner=“mca”})==1
And then the status field can maybe be used to differentiate the stat
For example
airflow_dag_last_status{dag_id="CORA",ddis="bla",env="acceptation",host="myhost",instance="10.251.101.246:8081",job="airflow_metrics",owner="mca",srvrole="airflow",status="failed"}
airflow_dag_last_status{dag_id="DORA",ddis="bla",env="acceptation",host="myhost",instance="10.251.101.246:8081",job="airflow_metrics",owner="mca",srvrole="airflow",status="success"}
What happened?
I can not get it in stat as i want.
When the status is succes i want stat to turn green.
When it is failed i want it red. -
See above -
No -
No -
N/A
