I need to build a Grafana chart that shows the number of completed test runs by status for a specific branch. For example, over the last 12 hours for the develop branch, 12 runs passed and 3 runs failed.
I have a Gauge metric defined in TypeScript:
this.runStatusGauge = new Gauge({
help: 'Test run status',
labelNames: ['runName', 'status'],
registers: [this.register],
I always set this metric to 1, only changing the status label:
this.runStatusGauge.set(
runName: this.runName,
status: '<passed or failed>',
1,
Then I group the metric like this and push to Pushgateway:
await this.pushgateway.pushAdd({
jobName: this.jobName,
groupings: {
env: this.options.env,
projectName: this.projectName || 'undefined project',
branchName: this.branchName,
As a result, Prometheus receives metrics such as:
test_run_status{
branchName="local-new",
env="staging",
exported_env="staging",
exported_job="pw_metrics",
instance="",
job="external-pushgateway",
project="",
projectName="widget",
runName="Local run name 5f99692c-32df-4d33-89f9-d2ddee90c1d9",
service="",
source="",
status="failed"
} 1
I’m trying to build a Pie Chart in Grafana, but it always shows separate values for each status, and they are always equal to 1. How can I make it display the total number of runs per status correctly?
