Cloudwatch variables based dashboard
Hi guys,
I am building a dashboard based on many variables that i’m filtering using tags on several objects (ELB, RDS, EC2 and maybe others).
The datasource is configured with arn and region.
The dashboard has a few panels all using variables.
The variables are defined as follow :
What happens, is that when i change the application variable, it takes sometimes a long time to refresh the subsequent variables like environment, instance_ids, etc… Actually, the first xhr query (using chrome dev tools) is like stuck for many seconds, and then all the others are executed normally.
Do you know a way to catch where things are slowing down the whole dashboard to refresh variables depending on each others ?
