I have a display issue on my pie chart.
Here is a screenshot of it :
What I would like is to cut the alarm names so that I always see the total time of it.
I have thought of cutting it in the query but then if the user hover over the line, it won’t display the full name.
Is there a way I can do that ?
Im using Grafana v10.3.1 (00a22ff8b2) on windows 10
Nope.
You may resize page in the browser (e.g. CTRL+-), scroll to the right in that legend, make shorter descriptions (e.g. rename ETHERNET → ETH, …), disable legend (so only value on hover will be there), …
But please you guys have to add the possibility to modify CSS properties of the widgets, it would add a whole new level of customisation to dashboards !
And it will add whole new level of user issues as well, so support engineers will be also CSS experts with cross browser compatibility knowledge from Internet Explorer 6
