Hi, I’m using Grafana v11.0.0 on a Rasberry.
I built a Dashbord showing me electrical currents:
I query IO-Broker via the Infinity-JSON-Datasource and as a Result I get a Table:
I would like to get rid of the long string and just showing “I1”, “I2”, …
I also would like to get rid of the string “val”
The Dashboard is “Stat”-Panel with “show all values” and fields set to “val”
I already tried “Transformations” and “Overrides” but they all go for the Table Header “id” etc. not for the “modbus…”
Regards
Martin
