I am trying to edit the branding with grafana enterprise using a docker container. Instead of trying to change the app title, login title, login subtitle in the custom.ini or grafana.ini files I am trying to use env variables like it says at the bottom of onfigure custom branding and using environment variables
The problem is I run the docker container with the env variables as shown in such pages, I can see the env variables existing inside the container (using printenv) but the login screen does not change in any way, I tried also editing the ini file inside the container but it does not change anything.
My docker command:
docker run -d -p 3000:3000 --name=grafana -e "GF_WHITE_LABELING_LOGIN_TITLE=NewTitle" -e "GF_WHITE_LABELING_APP_TITLE=NewTitle" -e "GF_WHITE_LABELING_LOGIN_SUBTITLE=NewSubtitle" grafana/grafana-enterprise
Docker env variables:
Could someone help me?
Am I doing something wrong?
