Features and enhancements
- Security: Update to Go 1.23.5 - Backport to v11.4.x #99123, @Proximyst
- Security: Update to Go 1.23.5 - Backport to v11.4.x (Enterprise)
Bug fixes
- Alerting: AlertingQueryRunner should skip descendant nodes of invalid queries #97830, @gillesdemey
- Alerting: Fix alert rules unpausing after moving rule to different folder #97583, @santihernandezc
- Alerting: Fix label escaping in rule export #98649, @moustafab
- Alerting: Fix slack image uploading to use new api #98066, @moustafab
- Azure/GCM: Improve error display #97594, @aangelisc
- Dashboards: Fix issue where filtered panels would not react to variable changes #98734, @oscarkilhed
- Dashboards: Fixes issue with panel header showing even when hide time override was enabled #98747, @torkelo
- Dashboards: Fixes week relative time ranges when weekStart was changed #98269, @torkelo
- Dashboards: Panel react for
timeFrom and timeShift changes using variables #98659, @Sergej-Vlasov
- DateTimePicker: Fixes issue with date picker showing invalid date #97971, @torkelo
- Fix: Add support for datasource variable queries #98119, @sunker
- InfluxDB: Adhoc filters can use template vars as values #98786, @bossinc
- LibraryPanel: Fallback to panel title if library panel title is not set #99410, @ivanortegaalba
Plugin development fixes & changes
Download page
What’s new highlights
