Changelog: Updates in Grafana 11.0.0-preview
Features and enhancements
Bug fixes
  • AuthN: Fix signout redirect url. #87681, @kalleep
  • CloudMonitoring: Improve legacy query migrations. #87648, @aangelisc
  • Azure data sources: Set selected config type before save. #87632, @bossinc
  • Loki: Fix log context when no label types are present. #87600, @svennergr
  • DashboardScene: Fixes editing transformations after toggling table view. #87485, @torkelo
  • DashboardDataSource: Fixes issue where sometimes untransformed data could be returned . #87484, @torkelo
  • Provisioning: Look up provisioned folders by UID when possible. #87468, @DanCech
  • Cloudwatch: Update grafana-aws-sdk to fix sts endpoints. #87345, @iwysiu
  • Select: Fixes issue preserving search term (input) when selecting a value. #87249, @torkelo
  • Alerting: Prevent search from locking the browser. #87230, @gillesdemey
  • DashboardScene: Fixes issue referring to library panel in dashboard data source . #87173, @torkelo
  • Data source: Maintain the default data source permissions when switching from unlicensed to licensed Grafana. #87142, @IevaVasiljeva
  • Alerting: Allow deleting contact points referenced only by auto-generated policies. #87115, @gillesdemey
  • Auth: Sign sigV4 request after adding headers. #87072, @iwysiu
  • DashboardScene: Fixes issues with relative time range in panel edit. #87026, @torkelo
  • DashboardScene: Fixes issue with dashboard links and variables. #87025, @torkelo
  • SQLStore: Disable redundant create and drop unique index migrations on dashboard table. #86867, @papagian
  • LogContext: Fix structured metadata labels being added as stream selectors. #86826, @svennergr
  • DashboardScene: Fixes issue with editing panels that uses instanceState. #86824, @torkelo
  • DashboardScene: Fixes deleting dirty dashboard. #86757, @torkelo
  • Alerting: Take receivers into account when custom grouping Alertmanager groups. #86699, @konrad147
  • LDAP: Fix listing all non-matching groups. #86689, @mgyongyosi
  • Alerting: Fix simplified routing group by override. #86563, @JacobsonMT
  • NodeGraph: Fix invisible arrow tips in Editor. #86548, @timo
  • Dashboard: DashboardPageProxy - Use chaining operators to prevent runtime error. #86536, @axelavargas
  • Cli: Check missing plugin parameter of plugin update command. #86522, @VergeDX
  • DashboardScene: Fixes issue saving new dashboard from panel edit. #86480, @torkelo
  • DashboardScene: Fixes minor issue transitioning between dashboards. #86475, @torkelo
  • MSSQL: Add SQL_VARIANT converter and update test. #86469, @aangelisc
  • DashboardScene: Fixes react panels with old angular options. #86411, @torkelo
  • Alerting: Fix simplified routes ‘…’ groupBy creating invalid routes. #86376, @JacobsonMT
  • AWS DataSource: Fix namespaces in sagemaker metrics. #86363, @tristanburgess
  • DashboardScene: Fixes saving dashboard with angular panels . #86255, @torkelo
  • DashboardScene: Fix empty row repeat issue. #86254, @torkelo
  • Nodegraph: Fix issue with rendering single node. #86195, @aocenas
  • Datasources: Add fixed width to name field in config editor. #86179, @sunker
  • Alerting: Return a 400 and errutil error when trying to delete a contact point that is referenced by a policy. #86163, @alexweav
  • Table Panel: Fix image disappearing when datalinks applied. #86160, @codeincarnate
  • LibraryPanelRBAC: Fix issue with importing dashboards containing library panels. #86149, @kaydelaney
  • DashboardScene: Fixes issue moving between dashboards. #86096, @torkelo
  • Alerting: Fix evaluation metrics to not count retries. #86059, @stevesg
  • Google Cloud Monitor: Fix interface conversion for incorrect type in cloudMonitoringProm.run. #85928, @adamyeats
  • Dashboard: Allow auto refresh option when saving a dashboard. #85922, @bfmatei
  • Time Zones: Fix relative time when using UTC timezone. #85779, @ashharrison90
  • PostgreSQL: Fix the verify-ca mode. #85775, @gabor
  • DashboardScene: Fixes issue with mobile responsive layout due to repeated grid item class. #85741, @torkelo
  • DashboardScene: Fixes panel edit issue with clearing title not resulting in hover header mode . #85633, @torkelo
  • Angular deprecation: Prefer local “angularDetected” value to the remote one. #85632, @xnyo
  • Chore: Fix trailing spaces in prometheus min step. #85579, @euniceek
  • SAML: Fix Authn request generation in case of HTTP-POST binding. (Enterprise)
  • Reporting: Fix CSVs for library panels within folders. (Enterprise)
Breaking changes
The @grafana/e2e package is deprecated in Grafana 11.0.0. If your Grafana plugin has end-to-end tests that use @grafana/e2e, it’s recommended to replace them with @grafana/plugin-e2e and Playwright. For information on how to migrate, please refer to the plugin-e2e docs. Issue #85778
Plugin development fixes & changes
Download page
What’s new highlights
