Features and enhancements
- Alerting: Make context deadline on AlertNG service startup configurable #96135, @fayzal-g
- MigrationAssistant: Restrict dashboards, folders and datasources by the org id of the signed in user #96345, @leandro-deveikis
- User: Check SignedInUser OrgID in RevokeInvite #95490, @mgyongyosi
Bug fixes
- Alerting: Fix escaping of silence matchers in utf8 mode #95347, @tomratcliffe
- Alerting: Fix overflow for long receiver names #95133, @gillesdemey
- Alerting: Fix saving advanced mode toggle state in the alert rule editor #95981, @alexander-akhmetov
- Alerting: Fix setting datasource uid, when datasource is string in old version #96273, @soniaAguilarPeiron
- Alerting: Force refetch prom rules when refreshing panel #96125, @soniaAguilarPeiron
- Anonymous User: Adds validator service for anonymous users #94994, @leandro-deveikis
- Anonymous User: Adds validator service for anonymous users (Enterprise)
- Azure Monitor: Support metric namespaces fallback #95155, @aangelisc
- Azure: Fix duplicated traces in multi-resource trace query #95247, @aangelisc
- Azure: Handle namespace request rejection #95909, @aangelisc
- CloudWatch: Interpolate region in log context query #94990, @iwysiu
- Dashboard datasource: Return annotations as series when query topic is “annotations” #95971, @kaydelaney
- Dashboard: Append orgId to URL #95963, @bfmatei
- Dashboards: Fixes performance issue expanding a row #95321, @torkelo
- Flame Graph: Fix crash when it receives empty data #96211, @yincongcyincong
- Folders: Add admin permissions upon creation of a folder w. SA #95365, @eleijonmarck
- Folders: Don’t show error pop-up if the user can’t fetch the root folder #95600, @IevaVasiljeva
- Migration: Remove table aliasing in delete statement to make it work for mariadb #95232, @kalleep
- ServerLock: Fix pg concurrency/locking issue #95935, @mgyongyosi
- Service Accounts: Run service account creation in transaction #94803, @IevaVasiljeva
- Table: Fix text wrapping applying to wrong field #95425, @codeincarnate
- Unified Storage: Use ssl_mode instead of sslmode #95662, @chaudyg
Download page
What’s new highlights
