Features and enhancements
- ** CloudMigration:** Create authapi service #96581, @leandro-deveikis
- Alerting: Add new button for exporting new alert rule in HCL format #96785, @soniaAguilarPeiron
- Alerting: Add option to show inactive alerts in alert list panel #96888, @bradleypettit
- Alerting: Add state_periodic_save_batch_size config option #98019, @alexander-akhmetov
- Alerting: Change default for max_attempts to 3. #97461, @stevesg
- Alerting: Consume k8s API for notification policies tree #96147, @konrad147
- Alerting: Enable flag alertingApiServer by default #98282, @yuri-tceretian
- Alerting: Explore button in Insights view #96496, @ppcano
- Alerting: Improve performance ash page #97619, @soniaAguilarPeiron
- Alerting: Make alert rule policies preview use k8s API #97070, @tomratcliffe
- Alerting: Return default builtin templates in k8s templategroup API and UI #96330, @JacobsonMT
- Alerting: Simplify notification step #96430, @soniaAguilarPeiron
- Alerting: Update state manager to take image only once per rule evaluation #98289, @yuri-tceretian
- Analytics Views: Deprecate :dashboardID endpoints in favor of uid/:dashboardUID (Enterprise)
- Analytics: Summaries: Deprecate dashboard_id endpoints in favor of dashboard_uid (Enterprise)
- Announcement Banners: Enable feature for all cloud tiers (Enterprise)
- Announcement banner: Remove feature toggle #98782, @Clarity-89
- Announcement banner: Remove feature toggle (Enterprise)
- Announcement banner: Sort by last updated (Enterprise)
- Auth: Return error when retries have been exhausted for OAuth token refresh #98034, @mgyongyosi
- Azure Monitor: Add a feature flag to toggle user auth for Azure Monitor only #96858, @adamyeats
- Azure: Improve Azure Prometheus exemplars UI/UX #97198, @aangelisc
- Azure: Unify credentials in frontend for Prometheus #96568, @yjsong11
- Chore: Bump Go to 1.23.4 #98853, @Proximyst
- Chore: Bump Go to 1.23.4 (Enterprise)
- Chore: Remove experimental Storage UI #96887, @ryantxu
- Chore: Update to node 22 #97779, @ashharrison90
- CloudMigrations: Enable feature toggle by default in 11.5 #98686, @mmandrus
- CloudMigrations: Introduce RBAC role for migration assistant #98588, @macabu
- CloudWatch: Add OpenSearch PPL and SQL support in Logs Insights #97508, @idastambuk
- CloudWatch: Batch different time ranges separately #98230, @iwysiu
- Cloudwatch: Accept empty string for logstimeout and mark errors downstream #96947, @iwysiu
- Cloudwatch: Update grafana-aws-sdk for AWS/AmplifyHosting metrics #97799, @iwysiu
- Dashboard Scene: Shows usages in variables list #96000, @harisrozajac
- Dashboards: Add option to specify explicit percent change text size for stat panels #96952, @XZCendence
- Dashboards: Allow DashboardDS subqueries in MixedDS #97116, @mdvictor
- Dashboards: Update docs of the
overwrite param in Save Dashboard API Call #97011, @ArturWierzbicki
- Datasources: Add toggle to control default behaviour of ‘Manage alerts via Alerts UI’ toggle #98441, @macabu
- Datasources: Allow clearing trace to logs, metrics and profiles datasource pickers #96554, @adrapereira
- Docker: Don’t use legacy ENV syntax #93218, @simPod
- Elasticsearch: Health endpoint should handle http errors #96803, @iwysiu
- Elasticsearch: Use _field_caps instead of _mapping to get fields #97607, @iwysiu
- Explore Profiles: Preinstall for onprem Grafana instances #97775, @ifrost
- Explore metrics: Consolidate filters with the OTel experience #98371, @bohandley
- Explore: Show links to queryless apps #96625, @ifrost
- Expressions: Add notification for Strict Mode behavior in Reduce component #97224, @shubhankarunhale
- Faro: Improve performance of TRACKING_URLS regex #98022, @kpelelis
- FeatureToggles: Make newFiltersUI feature toggle generally available #97460, @Sergej-Vlasov
- Features: Remove cloudwatchMetricInsightsCrossAccount feature toggle #98826, @idastambuk
- Frontend Sandbox: Add switch to toggle plugins frontend sandbox via catalog UI (Enterprise)
- Graphite: Set
maxDataPoints based on user value in alerting #97178, @aangelisc
- Licensing: Tidy up license token database code (Enterprise)
- LoginAttempt: Add setting to control max number of attempts before user login gets locked #97091, @kalleep
- Logs Panel: Add infinite scrolling support for Dashboards and Apps #97095, @matyax
- Logs Panel: Allow text selection without changing Log Details state #96995, @matyax
- Logs Panel: Limit displayed characters to MAX_CHARACTERS #96997, @matyax
- Logs: Added option to show the log line body when displayed fields are used #97209, @matyax
- Logs: Added support to disable and re-enable the popover menu #98254, @matyax
- Logs: Allow scroll to reach the bottom of the log list before loading more #96668, @matyax
- Loki: Added support for disabled operations in Query Builder #96751, @matyax
- Loki: Added support to show label types in Log Details #97284, @matyax
- Loki: Allow regex in
label derived field #96609, @svennergr
- Loki: Hide internal labels #97323, @svennergr
- Loki: Sync query direction with sort order in Explore and Dashboards #98722, @matyax
- OAuth: Support client_secret_jwt for oauth providers when doing token exchange #95455, @naizerjohn-ms
- OAuth: Use the attached external session data in OAuthToken and OAuthTokenSync #96655, @mgyongyosi
- Org Selection: Show correct selected org when select is open #96601, @yincongcyincong
- PDF: Add new zoom options (Enterprise)
- Plugin Extensions: Only load app plugins when necessary #86624, @leventebalogh
- Plugins: Add token to gcom requests #96261, @oshirohugo
- Plugins: Add token to gcom requests (Enterprise)
- Plugins: Disable version install when angular version is not supported #97189, @oshirohugo
- Plugins: Disable version installation for specific plugin types #98597, @oshirohugo
- Plugins: Update to latest go plugin SDK (v0.260.3) w/ arrow v18 #97561, @ryantxu
- Plugins: Use grafana-com sso_api_token #97096, @oshirohugo
- Plugins: Use grafana-com sso_api_token (Enterprise)
- Prometheus datasource: Show info annotations in the UI #97978, @zenador
- Prometheus: Improve handling of special chars in label values #96067, @NWRichmond
- PublicDashboards: Remove publicDashboards FF #96578, @juanicabanas
- Reporting: Add allow list email domain configuration (Enterprise)
- Reporting: Include the apiserver by default and deprecated internal ids (Enterprise)
- RuntimeDataSource: Support in core for runtime registered data sources #93956, @torkelo
- SAML: Add the ability to specify EntityID (Enterprise)
- SAML: Implement correct SLO with NameID and SessionIndex handling (Enterprise)
- Security: Update to Go 1.23.5 - Backport to v11.5.x #99122, @Proximyst
- Security: Update to Go 1.23.5 - Backport to v11.5.x (Enterprise)
- Snapshots: Add RBAC roles for creating and deleting #96126, @evictorero
- Storage: Removes integration tests for MySQL 5.7 since it is EOL #98013, @inf0rmer
- Tempo: Add support for TraceQL Metrics exemplars #96859, @adrapereira
- Tempo: Honor datasource TLS settings for gRPC requests #97484, @mdisibio
- Tempo: Improve handling of multiple values in the Search tab query generation #98427, @adrapereira
- ToolbarButton: Auto width on smaller screen sizes #96023, @yincongcyincong
- Trace View: Set span filters as panel options #98328, @adrapereira
- TransformationFilter: Implement RefID multi picker #96841, @Sergej-Vlasov
- Transformations: Add Delimiter format option to Extract fields #97340, @tskarhed
- Transformations: Add RegExp option to Extract fields transformer #96593, @leeoniya
- Transformations: GroupToMatrix add 0 as special value #97642, @tskarhed
- Zipkin: Run queries through backend #97754, @ivanahuckova
Bug fixes
- Alerting: AlertingQueryRunner should skip descendant nodes of invalid queries #97528, @gillesdemey
- Alerting: Allow notification policy filters to match quoted matchers #98525, @gillesdemey
- Alerting: Fix alert rule list view summaries #98433, @yincongcyincong
- Alerting: Fix alert rules unpausing after moving rule to different folder #97580, @santihernandezc
- Alerting: Fix ash not showing history graph in firefox #98128, @soniaAguilarPeiron
- Alerting: Fix bug when saving a rule more than once #96658, @soniaAguilarPeiron
- Alerting: Fix data-testid in RuleEditorSection #97473, @soniaAguilarPeiron
- Alerting: Fix filtering rule group permissions based on their full path (Enterprise)
- Alerting: Fix go template parsing #97145, @konrad147
- Alerting: Fix label escaping in rule export #97985, @moustafab
- Alerting: Fix missing instances and history when Grafana rule is stored in folder with / #97956, @gillesdemey
- Alerting: Fix navigating to URLs with “%25” #96992, @gillesdemey
- Alerting: Fix no-change scenario in provisioning rule update API #98389, @alexander-akhmetov
- Alerting: Fix not being able to remove a reducer when using range query #97757, @soniaAguilarPeiron
- Alerting: Fix recording rules rendering simplified condition #97497, @soniaAguilarPeiron
- Alerting: Fix removing reducer when inital value is instant #97054, @soniaAguilarPeiron
- Alerting: Fix simplified query step #97046, @soniaAguilarPeiron
- Alerting: Fix slack image uploading to use new api #97817, @moustafab
- Alerting: Fix terraform export of notification policy #98429, @moustafab
- Alerting: Fix updating condition when refId changes #97753, @soniaAguilarPeiron
- Alerting: Fix using stacks- prefix instead of stack- for checking the namespace in boot data #97492, @soniaAguilarPeiron
- Anonymous User: Adds validator service for anonymous users (Enterprise)
- Auth: Fix SAML user IsExternallySynced not being set correctly #98487, @volcanonoodle
- Azure Monitor: Add safety around usage of frame.Meta.Custom struct #97766, @adamyeats
- Azure/GCM: Improve error display #96921, @aangelisc
- CloudWatch: Fix conditions for fetching wildcards #98648, @iwysiu
- CloudWatch: Fix interpolation of log groups when fetching fields #98054, @idastambuk
- Dashboard: Fixes issue with compatability of old DashboardModel.annotations #97328, @torkelo
- Dashboards: Fix issue where filtered panels would not react to variable changes #98718, @oscarkilhed
- Dashboards: Fixes week relative time ranges when weekStart was changed #98167, @torkelo
- Dashboards: Panel react for
timeFrom and timeShift changes using variables #98510, @Sergej-Vlasov
- DateTimePicker: Fixes issue with date picker showing invalid date #97888, @torkelo
- Fix: Add support for datasource variable queries #98098, @sunker
- Fix: Do not fetch Orgs if the user is authenticated by apikey/sa or render key #97162, @mgyongyosi
- Fix: Double encoding of URLs when using data proxy #98494, @s4kh
- Font: Disable contextual font ligatures #98521, @ashharrison90
- GrafanaUI: Fix inconsistent controlled/uncontrolled state in AutoSizeInput #96696, @joshhunt
- GrafanaUI: Revert: Fix inconsistent controlled/uncontrolled state in AutoSizeInput #97551, @itsmylife
- InfluxDB: Adhoc filters can use template vars as values #98567, @bossinc
- Library Panel: Fix issue where library panels did not display panel links. #98655, @yincongcyincong
- LibraryPanel: Fallback to panel title if library panel title is not set #99411, @ivanortegaalba
- Loki: Fix a bug when reading frames without values but warnings #97197, @svennergr
- Loki: Only hide a set of labels instead of every label starting with
__ #98730, @svennergr
- Org: Fix redirection logic to work consistently #96521, @yincongcyincong
- Panel inspect: Fix file names of data download included uninterpolated variable names. #98832, @alexrosenfeld10
- Scenes: Upgrade to 5.36.3 #98661, @ivanortegaalba
- Snapshot: Show proper breadcrumb path #98806, @ashharrison90
- Time Picker: Fix “Fiscal year start month” selection behaviour #98576, @ashharrison90
- Unified Storage: Add support for verify-full in postgres #96825, @chaudyg
- Unified Storage: Use tls preferred when grafana db using ssl #97378, @owensmallwood
- Usage Insights: Fix usage insight errors being logged as [object Object] #93502, @mmandrus
Breaking changes
- Loki: Default to
/labels API with query param instead of /series API #97935, @svennergr
Plugin development fixes & changes
Download page
What’s new highlights
