Features and enhancements
Bug fixes
- CloudMonitoring: Improve legacy query migrations. #87647, @aangelisc
- Azure data sources: Set selected config type before save. #87585, @bossinc
- Provisioning: Look up provisioned folders by UID when possible. #87467, @DanCech
- Cloudwatch: Update grafana-aws-sdk to fix sts endpoints. #87348, @iwysiu
- Alerting: Prevent search from locking the browser. #87231, @gillesdemey
- SQLStore: Disable redundant create and drop unique index migrations on dashboard table. #86866, @papagian
- Alerting: Take receivers into account when custom grouping Alertmanager groups. #86697, @konrad147
- LDAP: Fix listing all non-matching groups. #86690, @mgyongyosi
- Alerting: Fix simplified routing group by override. #86620, @JacobsonMT
- Alerting: Return a 400 and errutil error when trying to delete a contact point that is referenced by a policy. #86162, @alexweav
- LibraryPanelRBAC: Fix issue with importing dashboards containing library panels. #86150, @kaydelaney
- Google Cloud Monitor: Fix
res being accessed after it becomes nil in promql_query.go. #85959, @adamyeats
- Google Cloud Monitor: Fix interface conversion for incorrect type in cloudMonitoringProm.run. #85957, @adamyeats
- Dashboard: Allow
auto refresh option when saving a dashboard. #85921, @bfmatei
- Reporting: Fix monthly schedule text and modify monthly schedule inputs behavior. (Enterprise)
- SAML: Fix Authn request generation in case of HTTP-POST binding. (Enterprise)
Download page
What’s new highlights
