Changelog: Updates in Grafana 11.3.3
Features and enhancements
  • Azure Monitor: Add a feature flag to toggle user auth for Azure Monitor only #97576, @adamyeats
  • Security: Update to Go 1.23.5 - Backport to v11.3.x #99124, @Proximyst
  • Security: Update to Go 1.23.5 - Backport to v11.3.x (Enterprise)
Bug fixes
  • Alerting: AlertingQueryRunner should skip descendant nodes of invalid queries #97829, @gillesdemey
  • Azure/GCM: Improve error display #97593, @aangelisc
  • Dashboard: Fixes issue with compatability of old DashboardModel.annotations #97467, @torkelo
  • Dashboards: Fix issue where filtered panels would not react to variable changes #98733, @oscarkilhed
  • Dashboards: Fixes issue with panel header showing even when hide time override was enabled #97389, @torkelo
  • Dashboards: Fixes week relative time ranges when weekStart was changed #98268, @torkelo
  • DateTimePicker: Fixes issue with date picker showing invalid date #97970, @torkelo
  • Fix: Add support for datasource variable queries #98118, @sunker
  • InfluxDB: Adhoc filters can use template vars as values #98785, @bossinc
  • Unified Storage: Use tls preferred when grafana db using ssl #97379, @owensmallwood
Plugin development fixes & changes
Download page
What’s new highlights
