Features and enhancements
Bug fixes
- Cloudwatch: Prevent log group requests with ARNs if feature flag is off. #75691, @sarahzinger
- Alerting: Add support for
keep_firing_for field from external rulers. #75257, @rwwiv
- Canvas: Avoid conflicting stylesheets when loading SVG icons. #75032, @adela-almasan
- Alerting: Prevent showing “Permissions denied” alert when not accurate. #74925, @VikaCep
- BrowseDashboards: Only remember the most recent expanded folder. #74809, @joshhunt
- Tempo Service Map: Fix context menu links in service map when namespace is present. #74796, @javiruiz01
- Logs Panel: Performance issue while scrolling within panel in safari. #74747, @gtk-grafana
- Bug: Allow to uninstall a deprecated plugin. #74704, @andresmgot
- Licensing: Pass func to update env variables when starting plugin. #74678, @leandro-deveikis
- Nested folders: Fix folder hierarchy in folder responses. #74580, @papagian
- Share link: Use panel relative time for direct link rendered image. #74518, @Clarity-89
- Alerting: Do not exit if Redis ping fails when using redis-based Alertmanager clustering. #74399, @alexweav
- Alerting: Refactor AlertRuleForm and fix annotations step description for cloud rules. #74193, @soniaAguilarPeiron
- RBAC: Chore fix hasPermissionInOrg. (Enterprise)
- Licensing: Updated grpc plugin factory newPlugin signature. (Enterprise)
- Reporting: Add support for old dashboard schema. (Enterprise)
Download page
What’s new highlights
