Features and enhancements
- Alerting: Add “Keep Last State” backend functionality. #84406, @rwwiv
- Postgres: Allow disabling SNI on SSL-enabled connections. #84249, @papagian
- DataQuery: Track panel plugin id not type. #83164, @torkelo
Bug fixes
- Elasticsearch: Fix legend for alerting, expressions and previously frontend queries. #84685, @ivanahuckova
- Alerting: Fix optional fields requiring validation rule. #84595, @gillesdemey
- ExtSvcAccounts: FIX prevent service account deletion. #84511, @gamab
- Loki: Fix null pointer exception in case request returned an error. #84401, @svennergr
- Dashboard: Fix issue where out-of-view shared query panels caused blank dependent panels. #84197, @kaydelaney
- Auth: Only call rotate token if we have a session expiry cookie. #84181, @kalleep
- Serviceaccounts: Add ability to add samename SA for different orgs. #83953, @eleijonmarck
- GenAI: Update the component only when the response is fully generated. #83895, @ivanortegaalba
- Tempo: Better fallbacks for metrics query. #83688, @adrapereira
- Tempo: Add template variable interpolation for filters. #83667, @joey-grafana
- Alerting: Fix saving evaluation group. #83234, @soniaAguilarPeiron
- QueryVariableEditor: Select a variable ds does not work. #83181, @ivanortegaalba
- Logs Panel: Add option extra UI functionality for log context. #83129, @svennergr
Download page
What’s new highlights
