Features and enhancements
- Alerting: Sort NumberCaptureValues in EvaluationString. #71931, @grobinson-grafana
- Alerting: No longer silence paused alerts during legacy migration. #71761, @JacobsonMT
- Auth: Add support for custom signing keys in auth.azure_ad. #71708, @Jguer
- Chore: Upgrade Go to 1.20.6. #71445, @sakjur
- Auth: Remove ldap init sync. (Enterprise)
- Chore: Upgrade Go to 1.20.6. (Enterprise)
Bug fixes
- Alerting: Fix edit / view of webhook contact point when no authorization is set. #71972, @gillesdemey
- AzureMonitor: Set timespan in Logs Portal URL link. #71910, @aangelisc
- Plugins: Only configure plugin proxy transport once. #71742, @wbrowne
- Elasticsearch: Fix multiple max depth flatten of multi-level objects. #71636, @fridgepoet
- Elasticsearch: Fix histogram colors in backend mode. #71447, @gabor
- Alerting: Fix state in expressions footer. #71443, @soniaAguilarPeiron
- AppChromeService: Fixes update to breadcrumb parent URL. #71418, @torkelo
- Elasticsearch: Fix using multiple indexes with comma separated string. #71322, @gabor
- Alerting: Fix Alertmanager change detection for receivers with secure settings. #71320, @JacobsonMT
- Transformations: Fix
extractFields
throwing Error if one value is undefined or null. #71267, @svennergr
- XYChart: Point size editor should reflect correct default (5). #71229, @Develer
- Annotations: Fix database lock while updating annotations. #71207, @sakjur
- TimePicker: Fix issue with previous fiscal quarter not parsing correctly. #71093, @ashharrison90
- AzureMonitor: Correctly build multi-resource queries for Application Insights components. #71039, @aangelisc
- AzureMonitor: Fix metric names for multi-resources. #70994, @asimpson
- Logs: Do not insert log-line into log-fields in json download. #70954, @gabor
- Loki: Fix wrong query expression with inline comments. #70948, @svennergr
- License: Enable FeatureUserLimit for all products. (Enterprise)
Download page
What’s new highlights
