10.0.1 (2023-06-22)
Features and enhancements
- Schema: Improve Dashboard kind docs and remove deprecated props. #69652, @ivanortegaalba
- Alerting: Update alerting module to 20230524181453-a8e75e4dfdda. #69011, @yuri-tceretian
- Caching: Update labels for cache insertions counter. (Enterprise)
Bug fixes
- Auth: Fixed CVE-2023-3128. #70581, @zerok
- Command palette: Include help links. #70322, @ashharrison90
- Tempo: Use pipe in TraceQL by default for multi-value variables. #70321, @joey-grafana
- XYChart/Trend: Fix min/max and units/decimals X field overrides. #70261, @leeoniya
- Explore: Improve logs volume panel empty state. #70255, @Elfo404
- Plugins: Wrap original check health error. #70227, @kousikmitra
- XYChart: Fix variable interpolation in datalinks/toggletip. #70210, @leeoniya
- XYChart: Fix formatting of axis ticks (units, decimals). #70193, @leeoniya
- Auth: Show invite button if disable login form is set to false. #70155, @IevaVasiljeva
- TextPanel: Fix styling missing the disclosure triangle. #70138, @joshhunt
- Alerting: Fix email template for text/plain emails. #70111, @grobinson-grafana
- Explore: Fixed Starred query history tab to show all starred queries. #70092, @harisrozajac
- CodeEditor: Ensure suggestions only apply to the instance of the edit…. #70067, @ashharrison90
- Command Palette: Links opened in a new tab now route correctly when Grafana is served under a subpath. #69925, @ashharrison90
- Heatmap: Sort fields by numeric names when single frame. #69880, @leeoniya
- CloudMonitoring: Improve parsing of GCM labels. #69812, @aangelisc
- NestedFolders: Fix select all in folder view selecting items out of folder. #69783, @joshhunt
- Alerting: Fix notification policies inheritance algorithm (#69304). #69782, @gillesdemey
- Templating: Fix updating of definition to empty string. #69767, @ivanahuckova
- Alerting: Support newer http_config struct. #69719, @gillesdemey
- Loki: Fix including of template variables in variable query editor. #69709, @ivanahuckova
- Azure: Fix Kusto auto-completion for Azure datasources (#69685). #69695, @aangelisc
- Alerting: Fix broken UI because of query being optional for some ExpressionQuer…. #69683, @soniaAguilarPeiron
- Explore: Run remaining queries when one is removed from a pane. #69670, @Elfo404
- Dashboards: Variables - Improve slow template variable loading due same variable loaded multiple times on time range change. #69641, @axelavargas
- Loki: Fix error when empty template variables response. #69559, @ivanahuckova
- Alerting: Add heuristics back to datasource healthchecks. #69541, @grobinson-grafana
- Util: Fix panic when generating UIDs concurrently. #69538, @JohnnyQQQQ
- Alerting: Fix provisioned templates being ignored by alertmanager. #69488, @JacobsonMT
- Log Context: Fix split view button using the wrong query. #69416, @svennergr
- Pyroscope: Fix wrong defaults when importing query from different datasource. #69366, @aocenas
- InfluxDB: Interpolate retention policies. #69300, @itsmylife
- SQLStore: Align SQLite IsUniqueConstraintViolation() with other backend implementations. #69227, @papagian
- Dashboards: Remove Explore option from panel menu when panel’s datasource uid is “-- Dashboard --”. #69173, @harisrozajac
- Alerting: Fix “show all instances”. #67837, @gillesdemey
- Usage Insights: Fix last viewed date. (Enterprise)
- Caching: Fix issue in which caching can cause HTTP resource response bodies to be written twice. (Enterprise)
