Hello, i am work in the table panel and need show when there is no data as a value (0). Achieving coloring the cell in red.
as an example
thank you very much for your time, regards
as an example
What data source are you using?
my data source is zabbix, use the plugin Zabbix 3.7 and Grafana is v4.6.2.
sorry not to speak Spanish very well, thank you very much from now for the interest.
Try to use groupBy() function.
